Ok i also have a question with the governor kinda. When i give it full gas and i get up to full speed, the engine rpms will lower a bit, then if i hammer the throttle it will go for a bit and then the rpms would drop, and then i would keep it pinned full throttle and would go vrooom, then lower rpms, like i was just revving it. Had this same thing with my predator 79cc so i just took that screw out that limits the throttle and it was fixed. So i did that to the 212 but it didnt change anything. Is my throttle cable not pulling it all the way or is this just the governor kicking in, cause im thinking about taking it out, the top speed could be way higher.
