J.S.@SMS
Road Hazard
I've got a few questions about the 670s, one of which I'm planning on using in a future build.
Question 1:
Are the bearing-less engine cranks and journals able to handle short periods of sideways thrust, like a car experiences when using the clutch, or will that wreck the crank and block?
Question 2:
How much power can the original carburetor support? I'm looking for around 30 horses.
Question 2 1/2:
If the stock carb can't support 30hp easily, how do I sync two slide carbs? I think I could make something that would work for an adjustment.
Question 3:
Should I go cheap and get the plain billet rods ($149.50 with no rod bearings) or spend the extra $50 and get a set with rod bearings?
Question 4:
If I'm running an external automotive cooling fan off a flywheel pto, do I need the engine cover, or would it get in the way (I'm looking for the cleanest possible look)? This engine will be in the front of the vehicle.
Question 1:
Question 2:
Question 2 1/2:
Question 3:
Question 4:
