Hello!
So I'm finally doing it. I am building my Predator 420 with almost everything. I have a billet flywheel and 65lb dual valve springs that are causing me problems. I think the flywheel problem is pretty simple. I want to figure out the timing of the stock flywheel so I can make sure I don't detonate at the wrong time and throw a rod. Is there any documentation about this? I can't seem to find it after a quick search. In terms of the valve springs, they don't seat nicely in the 420 head and had closer to a 70lb compression force compared to the advertised 65. does that matter? I got them in, but I don't want to start my engine have the springs stack, and ruin my new chrome moly push rods. any advice would help!
Thank you!
Laith Saah
Thank you!
Laith Saah
