Predator 212 with torque converter
jeeperjoel
san bernardino co., CA
looks really good!, i'm running a similar setup, un-governed 13hp i did a few mods to, 40 series comet knock off, #41 chain... 10 tooth on 45 tooth with 18" tires... keeps stretching the chain... just waiting for it to break... i'm happy at my gear ratio, plenty of bottom end, tops out as fast as i need to be going lol, any ideas on a stronger chain setup?
tazmannusa
Yettem, California
That looks great. How close is the rear sprocket to the ground though? Has it got enough clearance for offroading? It is hard to see from the pics
Thanks
The gearing could stand to be a little lower yet but it is a happy medium, that is an 80 tooth about 10" diameter and the tires are just a shade over 15" . plan is eventually to make a engine jackshaft plate with two jackshafts
tazmannusa
Yettem, California
Thanks
That is a tough one anytime you run a chain over that small of a sprocket at high rpm wears out quick . #40 , #420 are both a lot stronger even the #35 gold race chain is stronger than the #41 .
If you could go to a 13 and 60 tooth in the #40/#41 would help chain life or you could try a 14 and 65 tooth in a #35 with the race chain.
We run in dust and dirt and found that none of them last long
