Predator 212 to 224 swap
Skylark
As I mentioned in my into, I recently purchased a Carter Talon kart as a rebuild project. It currently has a tired Predator 212 which I am going to replace. I'm considering the Predator 224 but, I need to know if the output shaft and torque converter mounts are the same. The torque converter, belt and drive chain appear to be near new. I would like to re-use them if they will fit the 224. Any thoughts and/or advice will be appreciated. Thanks
Absolutely no difference. I own a couple of each. You'll like the extra torque provided by the larger displacement.
