Stage one kit. Governor intact. From 2013.
Question is which is more dangerous????
Gokarting or Football?
The state of Texas should have fun with that question on a Friday night. LOL
---------- Post added at 04:41 PM ---------- Previous post was at 04:21 PM ----------
Box Stock Engines require a stock connecting rod right?
And allow governor removal right?
I'm going to try to count the times he lets off the accelerator.
https://www.youtube.com/watch?v=Zi-PSZEf7XY
---------- Post added at 04:56 PM ---------- Previous post was at 04:41 PM ----------
BTW, since it is a 212cc on a Dingo with (assuming) 18" Tires you should be using a Torque Converter.
If a 30 series with 6" Driven pulley, it will have a 10% overdrive.
If you gear the kart 6:1 with a TC, in overdrive it will be 5.4 :1.
5000 RPM
5.4 :1 Gear Ratio
18" Tires
50 MPH.
I doubt you will reach 50 MPH with that engine and kart.
Maybe around 40MPH. With that gearing 40 MPH would be 4000 RPM.
Send It.
And if you happen to reach 50 mph going downhill, don't keep it floored there. The valves might float and that isn't great either.
Or keep the governor, TC, and 6: 1 gear ratio to reach top speed of 36 MPH.
Or keep the governor and TC, switch the gear ratio to 7.5: 1, and reach top speed of 28 MPH.
