Predator 212, post gov removal throttle linkage
Dallas, TX
B_Bimmer
I believe all that does is allow your throttle to be on the side of the engine. It says it has no effect on the governor. Governor removal is really easy, just get started and it all comes together. I usually use the rod from the governor to make a shortened rod directly from the throttle on the carb to the old hand throttle lever. Then I just add a spring somewhere convienent on the linkage to make sure I can always slow down and loosen up the nut on the hand lever so it moves freely.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
That is what that is. But youch! 35 bucks!
There are much simpler DIY ways to do it.
Checkout Affordable Go karts. There are How To instructions and they sell a much cheaper kit.
https://www.affordablegokarts.com/performance_basics.php
Also they have my Favorite instructions for Gov removal there too.
---------- Post added at 04:37 PM ---------- Previous post was at 04:32 PM ----------
Also here are some pics of when I did mine... Gov removal, Low oil sensor and Throttle linkage.
Also Bob58o posted his pics there as well.
http://www.diygokarts.com/vb/showthread.php?t=32730&highlight=2016+DIYGK&page=14
See page 13 and 14 of ^ that link!
Bbqjoe
Banned
Location, Location
AFAIC at this point, removing the gov doesn't add up to a hill of dingo's kidneys, unless you can reach 3600 rpms while riding, and keep it there.
Then I'd say go for it, you might get a little more speed, but your almost totally out of torque at that point.
To anyone, I'd now say don't even bother unless you're ready to throw some good money at it.
Without a much better carb, bigger springs, a billet rod, advanced timing, a better cam, different exhaust, changed gearing and a good port, you're just fooling yourself.
Prepare to spend the better part of a grand if you want an engine with an appreciable difference that will make you smile.
Again, JMO, and I'm standing by it.
Joe your tires are Huge (19")
Try something with 13" tires and get back.
In some cases it is the governor, in some cases it is gearing that limits RPMs, in some cases it is Tire size, in some cases it is valve springs,.....
Also timing, intake, exhaust, camshaft, carb, head, compression,....
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
I dunno Joe. It just depends on what you are doing.
I (illegally) drive my Kart 1 mile on the street to go to 7/11.
Without the Gov it allows me another 1800 Rpms.
Geared 6:1 with 15" tires the additional RPMs take me from a meager 27 mph Governed to 39mph
I will agree depends on the situation. In my case I am running a high speed high RPM for extended distances. As opposed to staying in the yard.
My Daughter never leaves the yard and her kart is Governed. In that case it is More than enough for the 2 acre property at 3600RPMs
Here's my scenerero, same cart, same 6:1 gearing, same TC, the 9hp is gov bypassed with 18" rears. The other is an 8hp gov attached with 22" rears.
The 9hp with the 18s will do about 40mph.
The 8hp with the 22s will do about 35mph.
That's top end. They both spin out on take off and I feel sometimes the 8hp has more bottom end sometimes. I would say my buttdyno is pretty accurate but it's not calibrated so it's only a rough comparison.
I thought the ungoverned would just whoop up on the other but I don't think it's so.
When my bro was in the 9hp and I was in the 8hp, he could not keep up. It was the same out running when we switched. I'm pretty sure it cause I know the karts and track better. I thought for sure one would out run the other but again it seemed they were very similar gov attached or not.
Let's over simplify and say a stock 212 can push a kart 40 MPH.Joe if you do the math, 6:1 with TC and 19" tires is around 37 mph at 3600 RPM.
Not much room for additional MPHs.
Same setup with 13" tires...
27 MPH at 3600 RPM, lots of room for additional MPHs
This is why I keep urging you to get more gearing.
Bbqjoe
Banned
Location, Location
I guess you have no idea how stupid a Baja would look with 13" tires!:p
I'm just going to sit still right now with this predator all stock, except gov, until I can beef the daylights out of my old engine, which was well on its way.
I gave a Baja to my nephew. I'm not really suggesting 13" tires.
But offering an out of the "Don't remove the gov" blanket statement offered.
Tire size matters a great deal.
---------- Post added at 10:06 PM ---------- Previous post was at 10:04 PM ----------
Really I would do a TC and jack shaft if I kept the Baja.
Especially if I had an engine eager to turn 7000+ like yours
---------- Post added at 10:10 PM ---------- Previous post was at 10:06 PM ----------
You can't talk gearing without tire size, you can't talk tire size without gearing.
Same same, but different... but still same.
https://m.youtube.com/watch?v=7tTfL-DtpXk
minibiker
USA
:iagree: and with cent clutches I noticed a big difference on my bajas but I geared 7.2:1 with 18 in tires topped out at 40 and got there quick. But you need lower gearing for the motor to wind up into higher rpms. I wouldn't but a throttle kit for a predator because its not needed . Its already ready for a mini bike or gokart, just loosen the 10 mm nut on the throttle arm and put a spring on it for safety to make sure it closes all the way after you open it.
:iagree: and with cent clutches I noticed a big difference on my bajas but I geared 7.2:1 with 16 in tires topped out at 40 and got there quick. But you need lower gearing for the motor to wind up into higher rpms. I wouldn't but a throttle kit for a predator because its not needed . Its already ready for a mini bike or gokart, just loosen the 10 mm nut on the throttle arm and put a spring on it for safety to make sure it closes all the way after you open it.
Please explain what difference you noticed with the CC.
Interested cause it is interesting. Or is it turned around?
I agree don't buy the kit.
Predators are set up for $5 bike brake cable to be tnstalled for a throttle.
minibiker
USA
I meant that with cent clutches the motor revs higher when geared right and you really notice the difference between governed and un governed . With a tav2 you have over drive and still goes pretty fast governed.
