Predator 212 only runs with starter fluid
Jaycarts
*I have Spark
*The governor is removed
*I adjusted the valve leash to spec 8/1000 exhaust 6/1000 intake.
*The valve cover does not have a gasket on it, but I don't see how that would prevent it from starting.
The ENGINE BRIEFLY RUNS OF A SQUIRT OF STARTER FLUID, then dies, as expected.
Thus, u guys would probably say its a fuel problem? However, the carb is brand new and clean, no debris, etc.
I am stumped. I have tried squirting the starter fluid into the air filter and it doesn't turn over, it only turns over when squirting directly into the intake manifold. But I inspected the air filter and everything and its clean.
It will only run with starter fluid being sprayed into carb that I’ve cleaned 4 times. Any help or advice
Hello and welcome...
How is the throttle setup...pics??
Recheck the position of gears and valve lash...
I have to say....there still might be some stuff somewhere.. (you did take out all the jets and Etube, made all passages clear with compressed air...)
Is the insulator cracked?
How is the fuel filter in the bottom of the tank??
WHat is the plug gapped to?
Jaycarts
Thanks but I think i solved it. All this time and headache and it was a bad spark plug. Thanks
