Predator 212 on E85?
JToTheIzzack
I've heard some rumors that running a predator on E85 will help it run slightly cooler, or even pick up more power. But if that's the case, I can't help but wonder why that big warning sticker comes on the engine saying no E85. Will running E85 on the engine with no mods have any effect, good or bad? My governor has been bumped up a little, just with the throttle adjustment screw, but the engine is still governed. I ask because my engine has slight overheating issues on hot days, and I'm looking for a super simple fix. Any replies would be much appreciated. On a sidenote, I'm thinking about adding a larger jet and emulsion tube, as well as a little walbro type fuel pump. If I do that, will that affect any interaction with E85?
Thanks!
E85 is alcohol fuel, typically the carb will need to be rejeted, then different fuel lines and other rubber type components. I thought hear something about the fuel reacting with the aluminum also.
Also a main thing, the compression is different for an alcohol engine, so more parts.
So in short, just run gas, cheaper the better.
JToTheIzzack
Cool, thanks for the info. Another thing I was wondering about is octane. I know that in full on automotive engines it prevents detonation and helps with timing, but does it make any difference in these engines? Like I said, my engine is totally stock. I once had to put some gas in it that had a bunch of octane booster in it that I used to use for pre mix in an old scooter, and it seemed just a little bit down on power, keep in mind this was 91 octane, plus however much was in there. It was a lot. Any idea why thisight be? I have a pretty basic understanding of it, but don't really know a whole lot about these engines yet.
Likewise, higher octane number(Well in North America, I know Europe has a different system) higher compression for running it efficiently.
Look here on more specs. http://en.wikipedia.org/wiki/E85
Just run regular 87 or there abouts.Any more wont run nicely.
FYI: I run ALL my engines on E10 (Aussie version of E85, with up to 10% ethanol @95 octane) &, so far, I've had no adverse affects; most actually run better than on standard unleaded
