Pred 212cc wanna b ALKY.
Relativity
West Tx
Ok, so if two hopped Predator engine that are souped up and running strong were not enough I want more, more, more get up and go. Truthfully this little yard kart has crazy power and pulls harder than any crotch rocket, or 4wd vehicle I had ever driven.
So like a crack head addict I want more and worse yet I want to share it with friends, family, and get them hooked on little nasty fast karts.
My solution, go stupid with alcohol!!!!!!!!!!!!!!!!!
My specs so far, ..... besides being 2014 Build-off Kart winner:
Harbor Freight 212cc (non hemi)
-ARC Billet Flywheel w/4 degree advance in timing
-RuiXing Carburetor w/140 emulsion tube and .037 jet.
-High Flow Air Filter Adapter and Angled Air Filter
-MOD2 Grind, Predator Core Dyno Cams
-ARC +.020 3.328 Billet Rod
-210FA PISTON Assembly (hemi piston)
-.010" Predator 212 Head Gasket
-Head, Racing, GX160/GX200 Honda
18cc (UT2 Casting)Springs:22lb Valve Size & Type:27mm Intake, 24mm Exhaust, Stainless
-DJ-1100 Ratio Rocker 1.3 ratio
-Autolite AR3910X Racing Spark Plug
-AKRA/WKA Box Stock Header & Muffler Kit
My question is what should I do to go alky?
Suggestion:
-Carb jetting size?
-Ignition timing advance?
-Clutch stall speed?
Some Half-breeder already recommended i go with a 1:3.5 final drive ration.
So people I am asking, help me and I will give you my performance baseline now and the effects afterwards.
Help me out fast! Dont want to keep yall waiting!
Some fun slow motion action!
<thead> <tr> <td class='tcat' colspan='2'><a href='https://www.youtube.com/watch?v=l3_Z9QfEm28' target='_blank'>https://www.youtube.com/watch?v=l3_Z9QfEm28</a></td> </tr> </thead> <tbody> <tr> <td class='alt1'><object width="425" height="350"><param name="movie" value="https://www.youtube.com/watch?v=l3_Z9QfEm28"></param><param name="wmode" value="transparent"></param><embed src="https://www.youtube.com/watch?v=l3_Z9QfEm28" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"></embed></object></td> </tr>
Logan County Ohio
There are some guys in our club running Alky in clones and Predators.
I can give you some general figures and tips. I think I heard right when one of 'em said "at least 38 degrees timing", now this would be dependent on compression ratio. I'm guessing here (nobody wants to give up there secrets) but 11.5:1 to 12:1 is probably the minimum CR you can run on methanol and this would be concordant with 38 degrees timing. More compression would require more advance. You can get pretty silly with compression on these motors before having valve clearance issues, the spark plug will get smacked quite a while before the valves. I have a head cut .092" with a .027" head gasket yielding 10.4:1 CR, valve clearance around 0.240" for pump gas, it will need one plug washer. With a .009" gasket it will go 11.1:1 with a stock dished piston and 0.018" less valve clearance and will need two washers. My clone has the piston only 0.0035" "in the hole" and I think most Predators are deeper, although you have changed rods probably in effort to reduce this. The bottom line is that I think you could get maybe 13:1 CR without fly cutting the piston if you are careful and running good valve springs. Always check valve and plug clearance.
Good maintenance is critical, the ARC rod should be replaced or at least checked after six races with new bearing inserts. The cranks on these engines are a weak point, I've seen 3 broken this year. Also the side cover must be checked for proper bolt torque each run. Which brings up another good point; Use studs and solid dowels on the side cover and studs on the head.
I don't have personal experience running alky in these guys but have been exposed to it usual from behind. I hope to remedy that this year and want to play with an E-85 motor too. NR Racing offers the proper E-Tube, pilot or idle jet and a big main jet to get you started on methanol as a package deal. Get a flywheel with lots of advance built in and some keys to boot for tuning. You will want to have different heat range sparking plugs for tuning purposes as well. One nice thing, Alky motors are a lot more forgiving as far as jetting, you can't run one too lean, it just won't run! They will run so rich as to spit raw fuel out the stack without killing the power.
I can tell you that with a mod-2 cam and healthy compression that you will want to set your converter to engage at no less than 4000 RPM. This will take the cast aluminum (147 gram) clutch weight for the Comet 30 series and at least a yellow or the blue/silver springs in the driver. They used to build a 90 gram weight but alas, no longer. Use the green spring in the driven and force it to shift up quick with the preload in the first or second hole. This is for max performance racing applications and depending on your needs can be fudged a little. The idea here is to launch the beast at or near its peak torque speed. You do not want to lug a high compression motor. This is what eats rods, bearings and cranks. This setup will far exceed the rated capacity of the 30 series Comet or knockoff but we have been racing them for a couple of years with good results. Component life is somewhat limited and maintenance must be stepped up.
Gosh, didn't mean to be so long winded but this subject is dear to me.
Louie
Poboy kartman
Senior Moments Member
White Settlement Texas
Well...Louie....Louie....ohhhh...baby....(sorry...I get distracted easily.....).....no....we never get tired of TOO MUCH INFORMATION.....as long as it's helpful.....and yours is.......
One point....he DID list a 32° advance flywheel in his parts list.....And ....it was in the back of my mind from the get-go....but I didn't want to say anything...but I was curious about carb mods for alky....as I know you need special carb parts and fuel pumps in drag cars......
Thanks for the info.....:thumbsup:
Logan County Ohio
Yeah, I missed more than the flywheel in the specs. I now see the 1.3 rockers and the small chamber. I'm guessing you should have about 0.125" Valve clearance, and between 11.5 & 12.1:1 CR with the emphasis on guessing. The real danger here is valve float, the more spring the better until you coil bind. Always check clearance. I am running the big chamber cut 0.092, yielding a chamber volume of 14cc, but I'm running 1:1 rockers with a 0.230" lift. I don't know for sure just how close you can safely run the valve clearance on these engines until I actually destroy one, then I'll have an idea. Anyone with experience in this matter, be welcome to comment!
I take it the ARC flywheel is 28 degrees out of the box so a 4 degree key would give you 32 degrees, sorry I missed that one. Methanol burns slow, therefore the need for 38 degrees + timing.
A bigger carb is probably in order since the motor is now breathing deeper, and various bored clone carbs, including "390" carbs are available already set up for alky., from NR. NR also has Mikuni.
Another thing I forgot to mention is that you might have trouble building heat (believe it or not), and some duct tape may be needed on the openings of the blower housing. And don't get too far from home without a bigger gas tank. (At least double!)
The carb and fuel system will need to be flushed with gasoline after each use as methanol along with the water it absorbs is corrosive to aluminum.
Ah, but what sweet music!
Louie again,
d340b
You also will have to use oil that is compatible with alky and change it often.
Regular oil turns to white goop from alky getting past rings.
Poboy kartman
Hmmmmmm........the ARC flywheel is 4° advanced....which is 32°....(stock 28°+4°)..... alcohol does burn slowly....a subject we discussed about high octane and compression on a different thread.....
So.....taking this all in.....if I understand correctly....he is running a higher CR...he is running a Mod 2 cam....which IIRC....has a recommended advance of 30° ....so would a 4° advance key possibly work???? (36° total advance)
And....strictly out of curiosity....for every degree of advance an offset key delivers....it obviously gets weaker....what is the most offset available....and do they break very often????
Logan County Ohio
I think some of our guys are running AT LEAST 38 degrees advance, they won't tell me all their secrets but I think some don't even use a key, they use red Loctite or valve grinding compound. I think I saw an 8 degree key somewhere (NR?). Don't ask me what holds it together! One of the guys was running a mod2 and he was the guy who told me that I would need AT LEAST 38 degrees. He did not tell me what his CR was, but I'm guessing around 13:1. He was hand starting this thing!
d340b
The key doesn't hold the flywheel. The taper does. All the key does is line it up for timing purposes. That's the reason for lapping in with valve grinding compound - it makes the flywheel fit perfectly to the crank and it won't slip.
Poboy kartman
If that were true....then all those motors that I have diagnosed here and at home that were out of time due to sheared flywheel keys wouldn't have happened.....:rolleyes:
Edit: While lapping it does make some sense...just putting it on and assembly makes more to me....if you rub something with computer paper, it slides very easily.....but if you rub it with coarse sandpaper,...it takes much more force to move it.,..same principal...I doubt pressure alone will do the job....
Badot
Plenty of engines have non-keyed flywheels. Same concept as on a drill press chuck -- clean tapers make an insane amount of friction.
It's just that a flywheel exposed to enough force to break the friction also will generally have enough force to break the key as well.
Poboy kartman
Can you name one????
