azarak
the yellow wire from the low oil sensor goes to a small gold box bolted to the engine case which has 2 black wires that splice into the kill switch circuit.
Question; what is the little gold box?
do i need the little gold box?
can i throw the little gold box away?
( i have pulled side cover, removed float sensor and plugged hole with a bolt and nut if that matters.)
