Powerland 420cc Carb
aham2003
Cleveland, Tn
Putting a intake and header (and removing governor) on a powerland 420 this weekend. Instead of jetting the factory carb, is there a carb I can buy that is ready to go out of the box? I dont know a lot about these Mikuni slide carbs that I keep seeing. I would like to have something that I can just bolt right up and not have to mess with jets or anything.
Thanks in advance.
Any aftermarket carb, or even stock carb, will require re-jetting.
On my Powerland 420, I am using an OKO 32mm. It seems to like 30 -32 pilot jet.
I haven't had a chance to mess around with the main jet. I have the needle clip in the middle position, but haven't tuned midrange either. I cap off the powerjet circuit with vacuum caps.
65ShelbyClone
SoCal
Instead of jetting the factory carb, is there a carb I can buy that is ready to go out of the box?.... I would like to have something that I can just bolt right up and not have to mess with jets or anything.
Not likely to happen.
You would be better off jetting the stock carb as there are fewer adjustments to make than with a slide-type bike carb and you already have a good starting point.
