Powerhorse Tuning Questions
TerryOlson
I just bought a new Powerhorse 208cc motor. It was damaged in shipping, originally sold through northern tool, returned, and ultimately sold through a discounter on ebay. The air cleaner housing was cracked and I got a pretty fair discount so I'm pleased with the purchase.
I see no mixture screws on the carburetor. I know it is set from the factory, but I'd like to lean it out just a hair because it sputters a bit on accelleration as you get toward the higher end of the RPM range. Not a huge deal, but I'd like to adjust it if I can.
I was certain the mixture screw was behind a brass plug on the side of the carb. I checked the google finding no exploded views of the carb and decided to remove the plug to access what I was sure was the jet. Instead, I found a series of tiny holes and it appears that this is one of the metering passages leading from the aircleaner end of the carb body. I don't know why there's a plug there - cleanout purposes maybe - but no jet or adjustment screw. I put it back in place humbled.
Anyway, can anyone steer me in the right direction?
As an aside - the engine really pulls nicely on the low end and it's very quiet compared to the old B&S it replaces. I really like the quality of parts - I'd expected something a little rougher in fit and finish but the engine seems pretty well built - save for the lack of carb adjustments.
I have yet to play with the governor and the throttle assembly is a bit funky, but a couple springs in the right places should resolve that. If not, I'll bypass the governor assembly and cap max throttle with a set screw to keep the kids from blowing it up.
Thanks in advance for any advice you can offer.
anderkart
Surprise Arizona USA
I'd suggest getting it all warmed up first and then while riding at full speed for 5 seconds or longer, suddenly kill the engine, coast to a stop and remove the spark plug to confirm if its reading a rich or lean mixture. (lots of plug reading info here: http://www.google.com/search?source...lz=1T4GZAZ_enUS369US369&q=reading+spark+plugs
If you confirm you need to re-jet, remove the float bowl. You'll find an orifice inside that extends down into the bowl and draws in fuel, you'll most likely find your main jet screws into that.
TerryOlson
We had some cooler weather yesterday and the kart runs perfectly (well, the engine does, I still need to replace the throttle cable and axle sprocket). Maybe the cooler weather helped - or maybe it's a break-in thing.
KieranM
Doin It!!
Kilkenny, Ireland
yea its possible that the weather was causing the fault, it happens on pocket bikes, when it gets warmer its reccomended to go a jet size higher, though im not sure if this applies to karts
MTU4X4RY
Houghton MI
Larger jet on warmer day?
KieranM,
Are you sure that it is larger jet when it's warmer? I thought that with cold weather comes dense air, the more air the more fuel, just my line of thinking though
