powerful enough?
kartkartkart
i bought a crf50 with a big bore kit in it for 50bucks will it be powerfull enough to pull me around? got a 30tooth rear sprocket and i think the stock 14 on the engine 3 speed autoclutch
KieranM
Doin It!!
Kilkenny, Ireland
What do you weigh?
What is its cc with the bore kit now?
As fowler said it would be great in a bike, do you plan to use it in a kart.
mcrende
I built a really light go kart it weight around 70lbs and it had a 49cc 2 stroke out of a pocket bike. I had about the same gear ratio you have with 10" tires and it got around at about 25- 30 mph but had zero low end grunt, I'm 6'2 and 230lbs so I think it will pull you around just fine.
