POS tempermental greyhound engine
Bluethunder3320
Do you not have lights where you live :roflol:
well my engines and tools and stuff is in the shed... i took a 100 foot extension cord and a lamp out there haha
while i was taking off the carb i found the problem, the fuel line was pinched by the fan housing.
its hard to start because of the compression, lifts the engine right up. but it started and ran!
it surges though. probably because of the gx160 carb. it sounds like it has a huge cam, idles like a drag racer. i think ill swap the carbs like i was meaning to do. and see if it fixes it.
Bluethunder3320
bolted up the motor, and went for a ride. no throttle yet, no brakes
then it high idled and i bailed out :surrender:
we lost the nut on the jackshaft so its broken again....
Bluethunder3320
alright it runs great now but it broke again. the keystock fell out of the sprocket. had to take my truck up there to go get it.
its fixed now, still works. throttle is you pull on a ratchet strap. LOL
then he crashed it and bent the spindle arm, tie rods, and popped the tire
I have a $5 solution for this thing: a gallon of gas & a match :roflol:
Man, did he break a mirror or something? Every time you get it going good, something else goes wrong...
Bluethunder3320
we got it going again, now the chain keeps popping off. the motor mount plate slowly walked itself back. the chain needs to be alligned
i guess you can count on having to fix it every day you ride it. LOL
Bluethunder3320
what car?
we had to go rescue it today haha. pull start broke, tire is popped, left spindle is bent 45 degrees, the frame just broke in 2 places
