Poppin and spittin!!!
hotrodhenson
My Baja Motorsports DN150 is sick. After my recent electrical fiasco (discussed and resolved in this forum, thank you again), the go kart ran but had a poppin and spittin fit at full throttle. I rebuilt the carbuerator, changed the fuel out, and installed a new fuel filter, and the go kart still has the problem. Is there a chance that there could be a vaccuum issue, spark issue, or just still a carb issue? I did replace the spark plug but the problem didnt go away. It almost seems like the kart is not getting enough fuel. Is the carbuerator gravity fed on go karts or does the diaphram on the top of the carb suck in fuel? I didnt put a kit in the carb when I rebuilt it so I was wondering if there was something in the carb that sucked in the fuel?
Thanks for all of the responses and advice. I appreciate it. Brian.
DCProductions
Cockney Ragamuffin
Louisiana, USA
If it's not getting enough fuel should be able to check the spark plug to see if it's running lean. I think your carb is gravity fed unless there is some sort of external fuel pump. If the fuel tank is above the engine I would expect that there wouldn't be a fuel pump. I found a fuel pump kit online, but it looks like an add on.
Hope this helps
