Running or not, if there's a return spring
properly attached, and the throttle plate hasn't been over tightened, it should return.
Double check that all of the nuts on the throttle linkage aren't too tight, causing too much friction. In fact, loosen them all a bit, and make sure the return spring has enough umph to return the linkage to idle. If not, beef up the spring. If it does, slowly tighten until it binds a little, then back off 1/4 turn then check again.
There
is a return spring, right? Otherwise, this is all moot. I can't really tell by the pic, but I don't see one. As Doc mentioned, industrial engines don't come with them. They're intended to be turned on, and left on, running at 3600rpm. Remote throttle control has to be added.
You probably already know that and I'm wasting my breath... err... virtual keyboard strokes. Just sayin' though
Sent from my XT1060 using Tapatalk
