Picked up a tecumseh 2 cycle engine and need help mounting it
TUK101
I picked up what I believe was a snow blower 2 cycle engine, I think a 3 hp. Everything is good, got it running after a carb cleaning and a spark plug cleaning. The only issue I am having is that I am going to either have to make a mount for it or if anybody knows if there is something pre-made it would help. I saw on Utube where guys are recommending these engines so there must be something to them, I just don]t see an easy way to mount it without having to pull the bottom crankcase bolts (which I hate to do). So, any help with this would be appreciated. I will try and get pictures tomorrow.
We are going to have to see pics of this engine before we can give you any mounting advice. Is it a predrilled mounting plate you are looking for that fits your engine? If so, we will need to know what engine we are dealing with
TUK101
I built a mount. This was an engine in one of those single stage snowblowers and often they are rubber mounted into a suitcase frame, not bolted like a go kart. But, it still had bolt holes for a pto or clutch etc so I built a mount for it. Now I can weld away to make a system to mount it to the go kart. Here is a pic of what I built.
TUK101
The side of another snow blower, an old blower from the 60's. I got a lot of useable parts from that thing. Like brass bushings, jack shafts, clutch, several sprockets and tin.
You've gotta like that. I had an older Sears blower that used a good centrifugal clutch and chain drive, instead of a basic belt system. I THINK they stopped doing it because of safety legislation.
TUK101
Yeah, that and belts are smoother and quieter. I have one more old Sears snow blower to dismantle. It has an 5 hp Tecumseh on it. This is another runner that the auger broke on. Now if I can just find an old riding lawn mower with axle and transmission I would be in business lol. I have horizontal shaft motors galore (about 8 of them) and just need an axle and wheels and tires. I am trying to keep this go kart projects costs down to a minimum and have noticed that tires/wheels are pricey.
The problem with using a mower as a donor is the fact that the drivelines tend to be set up for use with a vertical shaft engine. Occasionally, you can find an old rider that used a horizontal. A good alternate option is to source a rear-engine rider. These machines tend to use a transmission (instead of a transaxle) and feature a seperate rear axle (often with a differential). This is essentially what I used as a source for the Green Machine- the kart I built for my kids. I used the entire front axle assembly, front and rear wheels, tires, and a few other bits from it.
ML-TOYS
long island, new york
i have a 5hp 2 cycle from a snow blower but i kept everything i could for mounting it. what size shaft does yours have cause mine is a 1" output
ML-TOYS
i just got one of those antiques that has exposed chains and clutch, the motor has a blown shaft. i was wondering how that clutch is after all these years. the thing probably got used a couple times a year.
TUK101
The 3hp has a stepped shaft, the inner near the block is 3/4 and the keyed part on the end is 5/8. I ordered an 3/4 to 5/8 adapter sleeve so that I can use one of the clutches that I already have. That is what I had in mind is finding an old straight axle rear engine riding mower for a donor for this cart to get rid of the one wheel wonder rear axle setup. It just takes bolts through the wheels as axles.
TUK101
Thanks for the link. That is a very nice build. We had ours running a bit today, still trying to get the chain alignment just right. I also have to get the governor eliminated.
