Old Briggs and Stratton 3hp No Spark
sideways
Unfinished projects king.
Perth, Western Australia
points?????
look at the magneto............ its certainly electronic.
can you tell us the first 2 digits of the code stamped on the blower housing?
On the left, mounted to this 1979 4HP is a points coil, on the right we have the electronic ignition coil from a 1995 3.75HP. Both are Briggs mower engines. Don't give advice if you don't know what you're talking about mate, you do it a lot. I don't mean any offence, just saying.
jmadden91, the points wire appers to go into the side of the coil, the same place the thin red wire goes on yours. It looks like you accidentally pulled the wire out, it might not work if you put it back in. You might need a new coil.
I hope that helps.
Thanks
Hayden
jandj
Williamsburg, Va
If you gap everything, hook all the wires up correctly and still get no spark, BEFORE you buy a new one:
Pull the coil off and set it somewhere warm and dry for a few days.
I once set mine inside my grill (unlit, of course), got nice and warm in there when the sun shines on it. Also did one for a few hours in the oven at about 100 degrees.
Doesn't sound very scientific, but years ago when I started as a mechanic a veteran at my first job showed me this trick when the shop lawnmower crapped out. I've done it a couple times and it's worked. Doesn't mean it'll work for you, but it's cheaper than a new one and worth a try.
rog
Briggs 3hp no spark
I recently tried to start the same engine on a Morrison lawnmower and isolated the problem to no spark---the wire you refer to was connected to a spring arrangement between two pieces of metal at about 10.30 to the flywheel when looking face on. It may have previously been tampered with since I know my father had tried to start it after years of service and was unable to do so.
Unfortunately I am not likely to be able to check this out till I next go to where the mower is--in 3 moths time. In the meantime I had planned to get the flywheel pulled since I guessed that it was the next step to solving the lack of spark. Otherwise more details as to how the spark is created wud help and also assist is which spares may be needed.
Do you have a source of spares for this engine?
regards
rog
Briggs 3hp no spark
regards
rog
Briggs 3hp no spark
sori for the duplicate posting----I studied the photo of the engine again and from memory I see the place the wire was attached on mine.
In your photo detailing where u attached the wire, to the left and slightly up there is a red piece about 300 x50mm extending to the right from what looks like the fuel tank. It was held here--just pushed in, no screw. As I said I do not know if it had been reassembled correctly but it seemed natural for it to be there.
Regards
