off-road ice chest
txluke
Victoria Texas
I am going to build a cooler kart. It will have a frame that a cooler big enough for 2 people will sit on and the motor ( 5hp B&S) on the back. I want large tires and don't want to go fast. I will mostly be using this at BBQ cook-offs. I just dont know anything about gear ratios, clutches vs torque conveters, or belt drives. I can build anything and have all the tools. I just have no knowledge of karts so I humbly throw my self before the kart gods and ask for your wisdom.
B man
Tecumseh FTW!
Oliver springs,Tn
so you basicaly want i big slow 4-wheeler with a functional cooler body that has good torque and can carry 2 people?
since you said not fast. i bet with the right low gearing and a TC you could get away with keeping the briggs.
would you want suspension?
find out what tires your using.
use a bigger engine if possible.
you are going to want a TC.
i say find you an old 4-wheeler frame and modify it.
or if you like to build it give us some idea of size and we could help you come up with an idea
and Welcome to DIY go-karts!
txluke
Victoria Texas
The cooler I want to use is around 36 inches long. I have looked at tires and I figure 12-15 inch tires would be good. I am not wanting to climb rocks or jump off cliffs, just get around cook-offs where it is mostly dirt and grass, so I don't think I need a suspension. I have no desire to go any faster than a golf cart. I figure with riders, cooler, sound system, ice and beer the weight will be around 450lbs. I have built a few coolers with sound systems for floating the river and I plan on adding one to this cooler too. The first thing I need to figure out is what kind of torque converter, clutches, gears, ect. I would need and what motor I can get away with so I can start my sketches.
txluke
Victoria Texas
The briggs is on a tiller. Could I use the drive off of there to power my kart? It should have plenty of torque and low enough speed.
