Make some temporary bushings from tubing and lotsa grease.
bearingsdirect.com
No, i don't think so. The original bushings are plastic but they don't fit my axle. I am pretty sure it is 1 inch. I'll measure it with my caliper tomorrow1/2 x 1 1/8 inch maybe?
R8-2RS Mini Ball Bearing 1/2x1-1/8x5/16 99R8 S5PP
The R8-2RS mini ball bearing (1/2x1-1/8x5/16) offers smooth rotation and reliable sealing. Ideal for precision applications requiring reduced friction.bearingsdirect.com
I ended up wrapping the hug in electrical tape until it fit in the center snug. From what I can tell there is very little wobble.Nothing wrong with drilling the wheels, as long as you can get them on center.
It's just temporary so just don't try to hotdog it too much and it will be fine...as I said when you initially asked about drilling the wheels.I ended up wrapping the hug in electrical tape until it fit in the center snug. From what I can tell there is very little wobble.
That's been.the planIt's just temporary so just don't try to hotdog it too much and it will be fine...as I said when you initially asked about drilling the wheels.
My problem is the bolt holes don't have much meat between them and the center hole on the wheel. I am also gonna swap to Universal 4 wheeler suspension with disc brakes and some different wheels. The ones I am running now pretty dry rottedWrapping the hubs with tape to center them in the wheels, post # 47 sounds like a really good idea. If it came out centered and the hubs fit well you might just have a permenent solution.
