New to modding small engines
Sithis
NewMexico
So I got a yerf dog 3200 ( I think).
Anyway it came with a tecumseh OHH65 it wasn't running for the past 5 or so years. I decided to take the engine apart, cleaned everything up and the genius in me decided to remove the governor. Long story short I read about of engine failure and what a crappy engine it is known to be.
So I went and got a new 212 Hemi.
Anyway I am thinking of modding the engine before install and figured that by the time I am done with it the tec engine might be dead, leaving the Kart ready for a new power plant.
I haven't even opened the box on the Predator yet. What I want to know is if I get a beefier cam, how much is too much for the valve-train?
I plan on a port and polish for the intake and exhaust I probably will not start getting performance parts for a couple of weeks. I will pick up a flywheel and some #18 springs. If I change the flywheel, springs and cam will I have to replace the rod, lifters and rocker-arms?
Bubba_Z
Bubba_Z
Western NC
My 2 cents....I was thinking the same as you when I installed my 212.
Then I contacted ARC to talk about my build. The Tech took a few days to call, but I am so glad he did. He explained the same mods you are talking about will Rev that motor to 7k-8k RPM
The guys doing this are "Racing" expect the motor to last 6 to 10 hr's then need a rebuild. Maybe less if you run it hard.
The stock motor can last years. So I chose a middle road.
http://www.gopowersports.com/deluxe-predator-performance-kit/
This kit installed in 15min and added a bunch of power without throwing away reliability.
Now, if you still want more HP.....
https://www.youtube.com/watch?v=KQnjDf18evA
If you are not racing, you are not bound by the tracks rules.
Get a bigger motor.
A new engine needs break in time.
Also if you build a hot engine you have nothing to compare to. Take the new derp and run it. You might be surprised. Then after some seat time, ramp it up. Then you will know how much you improved.
Bubba_Z
Bubba_Z
Western NC
I agree with White, install the 212....Run it, install the $80 kit, then decide if you need more power.
Then if your like me.....see last line in this post
"Crawl,Walk,Run"
Wrench,Wreck,Repeat < not my quote....But it SO TRUE...Credit to original Poster.....(Who said that?) :confused:
Sithis
NewMexico
Yeah it is for my family. I don't need a drag racing kart I just want it to have some get up and go.
I am also unsure if I should change sprockets. it has a 40 chain.
and am i going to have to get a new torque converter or should my comet 20 work?
Staff Murderator
Sithis
NewMexico
Here are some pics. Took it on the road today. Speed test was 27mph max. Could I expect to see better gains from the stock predator?
Sithis
NewMexico
So the tech engine was on its last legs yesterday. I decided to put on the unmodified predator212. I just have to say I should have put it in the day I got it. It has way more torque and it gains speed much faster. I will do a top speed test on the unmodified predator tonight.
I will order the kit that Bubba_Z suggested today and will do another speed test when it's installed.
Kentucky Boy
Bowling Green, KY
Unmodded Predator 212's are good right out of the box for yard karts or kids. If kids are going to be riding it I wouldn't mod it or it could exponentially increase the danger and speed of your kart. I've modded mine quite abit. It's definately worth it if you want more power. No kids ride my kart.
---------- Post added at 12:08 PM ---------- Previous post was at 12:07 PM ----------
And yes, the 30 torque converter would be best for the 212.
pRoFiT
Can't buy it?, build it!
California
6:1 ratio with unmoded predator and 30 series TC, 15" tires gets you 0-27mph pretty quick. If you remove the govener then RPM increases to about ~5400 maybe more maybe less. That gets you top speed of 40MPH.
you have yerfdog with full suspension....that may be okay speeds. i think 27 is quick already for a yard kart. unless you want to race someone :) remove gov get 40mph! Try not to stay full throttle all the time. could brake something inside :)
p.s. I almost have the same mod kit on my mini bike! that thing is fast. and i think it still has gov.
http://redirect.viglink.com/?format...j29k129f-6ed959bc-9cc3-46b3-a2ba-7ff2782483a5
Sithis
NewMexico
So I installed everything. I don't know what the deal is but the engine seems to be running terrible. I'll try putting in the original jet and see how it does tomorrow
Sithis
NewMexico
What do you mean by terrible? What kind of symptoms is it showing?
It is sputtering when I give it gas and is running slower.
And to add: the stock predator 212 (with the governor) got me to 34 mph and accelerated much faster than the Tecumseh (without a governor).
Would it be safe to put a smaller sprocket on my axle shaft? I have a 10 tooth on the jackshaft and a 60 tooth on the axle. Can I maybe put a 30 tooth on the axle and still not burn out my clutch?
pRoFiT
California
30 tooth! 3:1 ratio...Everything i've read so far says thats a bad idea and you will be burning out clutches. No bottom end power at all and if you get it rolling then top end speed will be great.
Maybe something in the 50's would be okay. like a 5:1 or 5.4:1 ratio.
You don't put your car in 1st gear and get 50mph without some damage. That's why we have transmissions.
If you really wanted power and speed then a engine from an ATV with a transmission would be a better route.
Cheap way is lifan 4 speed motors for pit bikes and such. they have them with 125cc 4 speed for ~$300 on flea bay. i dont know what speed you get out of them. i do know my old honda 75XL could go 60 when pushed. so a 125cc should do the same if geared right? maybe?
Adding an ATV engine like the Lifan with a 4 speed would be nice, but it could be a huge pain to setup a reliable shift setup. An ATV engine with a CVT would be less of a headache for the most part. May have to use a push/pull cable still for forward, neutral and reverse, and hi/low if equipped. I'd probably leave the gearing as is, maybe keep it at 6:1 or as close as possible.
Sithis
NewMexico
Ok so I finally did a speed test. I worked out the hiccups and dang that sucker is fast! I got up to 42mph. I think it's definitely fast enough with decent acceleration. I can actually drive without having to mash the gas down the whole time. Thanks for the advise.
