Dukkie
I just purchased what i believe to be a Yerf-Dog Go-Kart Model #3202.
it has been engine swapped to a B&S (possibly 8-13 HP) i removed that and installed a predator 212.
The kart has a live axle with 60 tooth sprocket
The predator engine i installed a 10 tooth centrifugal clutch
18" rear tires
Small fronts (i wan to say they are wheelbarrow tires?)
I will have gearing questions as the kart has slow throttle response at low rpm with either engine installed.
I will have steering questions as...
i believe some of it is bent, should it be?
spacers to take up the wiggle in the steering knuckles.
turning radius.
some other questions i may not have thought of yet
if you can help send me a PM
18" rear tires
turning radius.
