New kart First post
rockb
Got a Kart for my boys and decided to get a new engine, since HF had one for $120, instead of throwing money at the old engine I would just put a new one on there and know it will run for a while.
I picked up a Predator 60363 from Harbor Freight figuring it would be an easy swap since a google search lead me here and I sat that there were others using them on Karts.
The first issue I see is that the throttle is so stiff it I do not see it springing back to idle when they let up on the peddle.
Is there already a thread here that discusses required modifications to make this engine work with a Kart?
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Loosen the throttle plate nut.. They're all tight for whatever reason..10mm I think it is.
Yep they are tight so if this engine is on say a paint sprayer or chipper shredder, you can set the throttle and run steady RPMs.
It is a nylon lock nut so you can just loosen it a half a turn or 1 and it will not fall off and your throttle will spring back to idle.
But wait.... There is only the governor spring bringing it back to idle.
You need to add a throttle return spring for safety. and make sure there is a kill switch easily within reach of the driver.
rockb
Working that issue now.
The engine has a yellow wire going into the Run/Off switch and then out of the switch to what looks to be the main body of the engine. I thought that switch was open to run and closed to shut it off but I used an Ohm meter to check and it appears shorted no matter what position the switch is in.:mad2:
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
That is a low oil sensor switch. It is designed to be there on an engine application that is sitting still on a pressure washer or paint sprayer.
On a go kart it ends up killing the engine every time you go around a corner or hit a bump. So yes with an ohm meter it will always stay the same regardless off the on off switch position.
What most guys do is use this for the operator kill switch.
1 Disconnect the wire from the engine block to the switch. leave the block wire alone.
2 extend the wire coming out of the gold box to a momentary switch on the steering wheel.
3 the other wire from the switch goes to ground.
Regardless of engine switch the gold box will kill the engine when the momentary switch is pressed. It will not "diesel" or allow the engine to restart on revs. You just restart the engine normally.
This is discussed further here: http://www.diygokarts.com/vb/showthread.php?t=33178&highlight=gold&page=2
page 2 specifically
---------- Post added at 12:59 PM ---------- Previous post was at 12:54 PM ----------
Here is more, and a video too!
http://www.diygokarts.com/vb/showthread.php?t=33317&highlight=switch
---------- Post added at 01:09 PM ---------- Previous post was at 12:59 PM ----------
Sorry these are good question that come up alot... ALOT. I am trying to help put them together on your thread here so I can reference it in the future.
So here is another link:
http://www.diygokarts.com/vb/showthread.php?t=11516
rockb
I feel like I'm defusing a bomb!
Cut the cyan colored wire, OH NO!!! The yellow! YES or is it the RED??????
lol
The pic is actually pretty good. I'm just kidding. BUT I can't see where the wires go on the bottom.
I need more arrows on the other side!
Disconnect the yellow wire under the green thing by the brown arrow.
Two birds.
rockb
Pic updated
Yellow arrows are the same wire but connected with a connector.
The black wire coming off of the oil pressure sensor comes around and then connects to the other two black wires, one going into the on off switch and the other going somewhere else.
The video you posted was very helpful. I just need to go get some electrical connectors. I hate cutting factory connectors off if I do not have to.
No rush. I need to order a new break actuator anyway. The one I got off of E-bay is incorrect. That is what I get trying to save a couple bucks.
This is the one I need.
http://www.northerntool.com/shop/tools/product_200323386_200323386
Two birds.
That will just disconnect the low oil cutoff correct?
