Alright so I bought a second hand electric go kart project online and my main intention now is doing it up.
It's rather DIY and quickly done with no contactor, undersized wiring, no fuse or precharge resistor and unmatched batteries etc that I plan to fix all the problems.
My question is What size ohm precharge resistor do I need inline with the contactor which will also be placed online from the battery positive to motor controller
Also What size fuse do I need from battery positive to motor controller....
all 5 of the batteries will soon all be rt12220Ev ritar batteries. 12v 22ah. 20hr
the motor is a 60-72 volt 1800w (BM1424ZXF)
the controller is undersized for some reason rated at 1.5kw so 1500w and 60volts 45 amps.
all of the yellow blocks are just terminal block connectors
