Need thoughts on possible solution
Brandon1023
needs an oil change
Miami, Florida, Dade County 305
Today I had a broken Briggs 4.5 HP push mower dropped off to my house to fix. So I went through the same old trouble shooting process. Got it running after a lot of carb cleaner and much priming of the bulb. Obviously I didn't think it was fixed, so I pulled the tank off, cleaned the carb, and now it runs too rich. Details below.
  • Briggs and Stratton 4.5 HP
  • Diaphragm-Style carburetor. Plastic throttle housing with the metal portion of the carb built in to the gas tank. Here's a link to how the carb layout looks. http://i2.photobucket.com/albums/y46/baymee/Step2Briggs-375-removing-govern.jpg
  • Strong spark - engine runs perfectly fine, starts up in about 2-3 pulls. Not ignition issue.
  • Carb was very dirty, but these things clean up pretty easy.
  • Engine made in December of 2004, but it looks like it was used moderately. Aside from the bail of hay he had in his cooling fins, and the mud cake of an air filter, it seems like it's worth fixing it.
*Solution*
I was browsing google, and came across a thread where a user said they had the same problem and someone suggested that the flappers on the diaphragm are stretched or worn and that replacing it should do the trick. Does this sound like the solution?
