need help
Daniel Sheffield
San Antonio, tx
hi, im new to this so bear with me please. I got this cart from my boss for free and have some questions. there was no fuel tank on the engine like it should and i rigged a temp one for now, (that red plate on the front). there is however a tank of some sort on the seat. is this a fuel tank and if so would i require a pump to use it.IMG_20160111_173946.jpg
Daniel Sheffield
San Antonio, tx
more than likely it was used for the fuel tank. the way it's set up as, it wil need a fuel pump. the stock fuel tank was a gravity feed tank. http://www.jackssmallengines.com/Pa...J87WI_7gkiZG-8st1bVYxOOAPm2npcQkPbhoCvpzw_wcB if you dont want to use a fuel pump the fuel tank will need to be above the engine. looks like were the original fuel tank was is a old snapper mower fuel tank bracket.
Would a pulsed pump damage the carb any. Being a float type. It seems it might not allow needle to stop fuel
rocketkart
florida
i knew that.
Rocket, If you look at the picture of the back of the seat you will see the gas tank there. :thumbsup:
i knew that, but thay have a bracket where the original fuel tank was on the engine. :thumbsup: and yes A vacuum pulse pump should work fine.
