Need help 27hp engine
srwolf173
I was given a Kohler 27hp vertical shaft engine from a riding lawn mower with a bad trans. I'm not worried about the shaft I can make an adapter for that, my problem is what to do for a trans. I haven't found a torque converter or centrifugal clutch that can handle the hp any budget friendly ideas? Cart currently has the 6.5 hp engine and a centrifugal clutch was going to upgrade to the $100.00 torque converter before I got the larger engine, cart is used primarily in parades so lots of hills and stop and go traffic.
Hello and welcome....
Id keep what your running, get the TC, shelve the vert shaft... They're a hassle to convert to use properly, and the TC meant for that size are big bucks...
