Need Advice! 8hp too power-full???
jmanjtight
heres my cart...in the works...
54 tooth sprocket on axle / 12 tooth on clutch
6.5 hp motor... which is a piece of junk, so I am thinking of putting a 8hp Briggs and Stratton I have on a wood chipper on the cart.
would it be too powerful for this little cart??
Brandon1023
needs an oil change
Miami, Florida, Dade County 305
Whether or not it's "too powerful" is your decision. I have a 13 HP on a similar set up and that is too much power for 1 wheel. However, if you plan on getting an 8 HP engine, get ready to cough up around $100 because you'll need a clutch with a 1" diameter, not 3/4", as the crankshaft is going to be an inch in diameter.
Welcome to the forum.
Jcotz
...wasn't there
NY
The engine will probably not be too powerful, but with the gearing you'll have you will probably be getting more speed than you want. Also, your acceleration will be pretty bad.
The engine will be fine. All you do is gear accordingly. I would say that your gearing at the moment is horrible. You have 54/12 = 4.5:1. That is waaay to steep. You are going to have to go to at least a 72T axle sprocket to get any decent torque
Nodroz
Belgium (Europe)
:iagree:
I have an 8 HP Kohler engine it has a 3/4" shaft. You will need to measure the diameter to be sure it's not a 1" shaft. Else the clutch will be expensive.
Would it be too powerful for this little cart??
:roflol::roflol::roflol::roflol::roflol:
Sorry, I have to laugh; TOO POWERFUL? ARE YOU KIDDING?
IMO, there's no such thing; it's how you use that power that counts.
Geared low enough, you should be able to get a decent top speed out of it and have a mass of torque for acceleration
Maybe for one but it looks like he's using a live axle
I think he'll be safe. 8hp B&S only has a 3/4" shaft
