Louie The Lot Lizard
Took delivery last week of a brand new BOX STOCK SPECIAL, spent a couple of days tearing it into little pieces.
Why a BSP ?
1. It came with a bored carb.
2. Has trick valve springs and a mild cam upgrade. The springs are still 10.8# on the seat but have a higher nose pressure than stock.
3. Has a "heavy duty" forged stock rod. More on this later.
4. This rod seems longer than stock and the deck has been cut so the piston is only .0035" in the hole.
5. It has a max stroke crank.
6. It has a JT high flow head.
A lot of stuff for $175.00 with shipping.
Wrinkles?
1. There is NO crank end play.
2. Top ring gap seems a bit tight @ .009".
3. The rod and piston are quite heavy (there isn't much difference with a billet rod either) and these engines seem to be shaking themselves apart.
Angles
1. Have engine balanced, I found a shop that will do it for $60.00
2. Use of stock albeit "heavy duty" rod. The machinist told me to buy a half dozen of 'em at a time, run a race or two and change 'em. At $15.00 apiece its cheaper than a billet rod that no one in our club has made it through the season with.
3. Running low tension rings to free up HP.
4. Using as light a valve spring as I can get away with for the same reason.
5. Running a raceseng S2 flywheel with adjustable coil mount to spool up quick.
6. Using a BSP 3 cam, perky with a wide torque range. Plan on 6500 RPM top.
7. The head is a 22 cc unit, I haven't cc'd the thing yet but plan on about 10.4:1 for pump gas. With a stock dished piston this looks to require about a .050" shave job, I haven't checked valve clearance yet so this isn't written in stone yet.
8. May need to grind bearings to get end play as it has a thick gasket already, will try another on top of it first.
I'll keep you posted.
Go fast, turn left.
Why a BSP ?
Wrinkles?
Angles
Go fast, turn left.
