My "new" CAT99 torque converter
redsox985
PA
Possibly. The driver isn't stamped with CAT99, though. The only part marked with CAT99 is the black plastic cover. Which, correct me if I'm wrong, has not changed in size, just stickers.
r97
Measure twice cut once
Massachusetts, USA
maybe you just have a 30 sereies setup whith some cover someone baught off ebay and slapped on there cause it fit
redsox985
PA
Hopefully lol. Does anyone know any distinguishable differences between the CAT99 and 30 series?
redsox985
PA
I know the belt. The spring just looks metal color. Did they color the springs a while back?
redsox985
PA
I've been all over that site. It's a 6" driven with a 5/8" jackshaft and 3/16 keyway. The driver is made for a 1" shaft with a 1/4" keyway.
redsox985
PA
Does anyone have a CAT99 that they can take dimensions from so I can compare it up to mine? Not stuff like driven OD but stuff that varies between the CAT99 and 30 series.
Thanks a ton.
Kenny_McCormic
Kartless....
Michigan Troll
That's your driver, To ID the driven put it together and measure the gap between the halves?
redsox985
PA
Driver
-Fixed
OD 4 11/16"
Shaft 1"
Shaft sleeve OD 1 1/8"
Shaft sleeve length 3/4
Fully closed top gap 9/16
-Moveable
OD 4 9/16"
8 internal ?teeth? to lock to cover
-Cover
OD 4 3/4
Shaft 1"
8 external ?teeth? to lock to moveable
-Weights
2 piece
ID 1 5/8"
OD 2 11/16"
Posts 1 7/8
Springs: 2 continuous rings
Inside of weights spamped 2-2 02931
Driven
-Fixed
Post 2 11/16"
Stamped "3/4"
OD 6"
ID 5/8"
6 Rivots
Back stamped "Richmond, Indiana"
"Comet Industries"
-Moveable
3 buttons
Stamped "3/4"
Steel bushing
OD 6"
ID 1 1/2"
-Info
Spring 1/8" wire
Spring 4 1/4 turns
Color unknown looks like bare metal sanding showed clean steel
1 vertical post for cam 1 horizontal for driven moveable
Back Plate & Jack Shaft
9 15/16 long
Stamped "Comet Industries"
"Pat. No. 3747721"
8 Bolt Holes
10 tooth sprocket
3/16 keyway
2 Bearings "99502H PEER ROMANIA"
Grease Zerk
Solid sleeve between bearings covered in grease
Bearing housing on back 2 1/4" long
Any ideas on giving this thing a solid ID and where parts are available for whatever it ends up being.
redsox985
PA
After looking at that...I concluded nothing except the backplate was designed a while back lol. I'm more concerned with what type of TC I have. I'm assuming a 30 series driver due to the stamped in 3/4". The driver is my real concern. Does anyone have a CAT99 driver that they can compare my specs to? Thank you.
