r_chez_08
Should be in the shop...
OK I have most of the parts together for the 6.5 clone build up. Its only a mild build but I hope for 11-12hp (a well setup box stock clone produces 9hp with wiener pipe and air filter).
What I am doing:
Governor removal (free)
Free flow air filter and adapter ($8 + free with lathe)
Flat top piston ($16 + $8 rings)
Billet arc rod, std length ($55)
Genuine honda 14cc gx160 head (11.8:1 compression) ($30 paid for 2x heads and 3x carbs, plus a load of other gx160 stuff)
BSP-1 cam (stock lift, a little more duration, $15)
16lb gx160 G4 valve springs ($5)
Homemade ratio rockers (free)
Aluminium gxv160 flywheel (I hope, $50)
DIY free flowing header with an I/D close to the port size (free)
I may bore the carb (free)
8* timing advance (free, filed down)
Rejet carb ($10 for the drills)
Genuine NGK bp6es plug ($3)
No resistor in the spark plug or plug cap (free)
SKF higher quality bearings ($15)
total around $200 (eek! I didnt realise I spent that till now!!!)
I was originally planning on just a flat top piston and air filter mod.
I am now hoping for a torquey motor for my kart. 60t rear, 9t jackshaft, comet 40, 19" tires.
I am not planning to go over 6k with this motor, because that equates to 50MPH!!! The frame was welded by me and my brother. I may go down to 8t jackshaft, 45mph @6k
I mainly wanted bottom end, which is why I jacked up the compression and I am leaving the stock valve size. I have heard a 22mm mikuni would hurt bottom end, along with a high duration cam.
If i have the money in the summer, I hope to get an NR racing $60 winch board cam, which makes awesome torque from 3500-5500 rpm. Or a BP-2 cam which is $50 and meant to make 2hp more than the stock cam.
Rod and flywheel mods may not be neccesary but I got the rod for $55 shipped to the UK and it should be far more durable than the stock cast one, because it has a forced oil dipper, which will lube the crank journal up nicely.
I hope to modify my torque converter rollers on a lathe to lighten them. Here it says that I could have a 2400 rpm engagement with light rollers. I know that stock rollers weigh 128g, and mediums weigh 97g, so I could make some light ones around 70g or so. Then the clutch would hit in when the motor is making more power.
I will get some pics later.
P.S. DONT START TO MOD YOUR CLONE!!! IT IS REALLY ADDICTIVE!
What I am doing:
