My great idea!!
n1kogr
Mass
Hello im new to the forum and decided to post my little idea ive had for a while... To start with i built a lil mini buggy and threw a duromax 16hp on it and it runs great.. i cut corners though and bought a clutch for it instead of a torque converter because i dnt have the money at the time so decided clutch was my best bet ( clutch rated for 13hp but so far has held up great)
Anyway i have a blown up yz85 engine that has a cracked cylinder.. the bottom end is perfect but top end is junk. I was thinking if i take the flywheel off and some way put a sprocket on it and then a direct sprocket on the duromax wouldn't i have a 6spd cart.. its hard to understand but i hope youll get my point... thanks -Nick
Is the YZ85 capable of handling the hp/torque of the duromax engine? That would be my first thought.
karl
North east Ohio
The yz85 has about 18hp so dont worry about it. Take the connecting rod out and make a plate to seal the top end off.
n1kogr
Mass
thats exactly what i thought about the hp.. and thats exactly what i thought about the conecting rod and plate for the top end haha i also thought about a semi automatic honda trx 125 engine i have... it has 5 gears and REVERSE but the only thing im skepptical about is the power and if that lil engine would be able to handle the duromax what you guys think? btw thanks for the replies
Wim
Jazz Maverick
Oz
Its worth a shot. I'd say most 125cc jap-bike transmissions could handle ~16hp, they're pretty tough.
n1kogr
Mass
i am about to start this but now my only problem is what if the engine bends the crank... do you think a sprocket welded to the flywheel wont bend it or is there a way to reinforce or something... thanks for the help
