The number with the arrow cross references to a larger part number that might still be in a warehouse somewhere. If you put "Murray bushing 1201110" into your search engine of choice there might be some out there. Much of these kart components, from any manufacturer, were generic off the shelf parts. I bet 2/3rds are still found in their riding lawnmower inventory...
Making good progress on the build
Need to finish the cooling system and do electrical.
Decided to ditch the manual brake and go with dual hydraulic rear brakes
What a beast! You’re going to need some hydraulic brakes for that thing and at least 2. I initially thought you were restoring the kart to original “fun kart specs” but I think you might need those ball bearing supported spindles they use on race karts and to tighten up all the looser tolerances thereabouts.
