Murray Go Kart Rebuild
Ragnar4077
Western Washington
Hello all! Last year, my father and I picked up a Murray, and have been working on it ever since.
:cheers2:
We have put on a 212 cc, stage one kit, new torque converter, wheels, and we are now just doing the unecesary stuff to make it more fun.
Any thoughts on making it faster?
anickode
S.E. Michigan
:cheers2:
Well, beyond the basic bolt on stuff, you have to start looking inside the engine. You've presumably removed the governor already, since the gains from a stage 1 kit will mostly be seen above 3600 rpm.
Have you rejetted the carb as part of the stage 1 upgrade?
So the next things to look at would be compression ratio and timing advance. An offset timing key and thin head gasket might be a good place to start. You might need to run premium gas at that point.
A mildly fatter cam would also be an option, however anything more than a mild cam will need stiffer valve springs, which will allow a ungoverned engine to spin faster than 5000rpm, and you can't safely make it rev higher than 5000 rpm without doing a billet rod and flywheel.
Ragnar4077
Western Washington
We will remove the governor. Thanks for telling me that the governor removal makes the kit better. I got the kit from gps, and with it came a rejetted carb.
