Mountain bike brakes on go kart?
ggaige
]I already know that v brakes from a bicycle don’t work to well on a go kart but what about a disc brake from a mountain bike(the brake in the picture). Would this brake be able to stop a go kart going like 25 mph?
RobertD
Administrator
Texas
That sounds like a bad idea, as the weight of a kart is far higher than the weight of a bike. You could look up what that disc/caliper combo is rated for and have a better idea. Plus you have mounting issues..
I'm building small karts for my grandkids & I'm using pocket bike brakes...
There are just about no bicycle parts that can be used on a go kart...
anickode
S.E. Michigan
I wouldn't say it is a definite no. Mountain bike disc brakes have to provide a LOT of braking torque to compensate for the disproportionately large wheel diameter to rotor diameter ratio. And they can do that with perhaps a 200# rider going down a 100% grade.
What they are not meant to do is grab down on a disc that is spinning 1000 rpm, so pad life could be adversely affected.
On a yard kart that does 25mph and weighs a couple hundred lbs with rider, and having brakes on the axle AND front wheels, they would probably be just fine.
Biggest problem I could see is mounting. By the time you figure that out and buy or make the parts, you could have gotten a complete mechanical disc brake kit that is designed for go karts from gps for 60 bucks.
Randy H
Well as cool as a glowing rotor is, I have to admit I was a little disappointed that it didn't stop that chuck instantly and send engine lathe gearbox parts about the vicinity.
I am also disappointed he didn't have the chuck into neutral... But to see how long the brakes go before a problem... Kinda gives a different/ better perspective...
Kansaskart
I didnt watch it and now I wont lol.
