Motor reccomendations?
TheFauxFox
Just another newbie here (lol).
I'm looking to take a Yerf Dog (esque) frame (~350 lbs) and make it run 40+ mph on 24(if possible), 36 or 48 volts. I am open to dual rear motors....what do I pick? I don't think that dual 1000w my1020s geared low will even get me that fast?
I know others have some good motors...any suggestions?
And also, how can I calculate speed? There must be some equation?
Thanks, all!
-Ryan
TheFauxFox
350 Lbs is what the frame weights?
Approx. 350lbs for frame. 500lbs total
What I'm trying to ask is..."for under $300 (motor wise, before sprokets and gearing) is it possible to get 500lbs rolling at 40+mph with approx 15in tires?
fresh101
Pembroke Pines, FL
I believe a dual motor setup is required and because of weight you will need torque decreasing top speed. I see approx. 25 Mph at 48v with that much weight. If you can get yourself a good controller to push 100 amps @ 48v to the motor it will compensate for the torque needed and using 13 tooth motor and a 55 tooth rear sprocket, it will get you about 43 Mph but because of weight i would say anywhere around 33+ Mph. This is how I would do it.
You put a price tag of $300, each 1000 watts motor run you about $100 each and require 1 controller for each, going over your $300 price tag.
I am doing my calculations based on my own experience but someone else can help. I use 1 - 36v 1000 watts motor on my scooter @ 48v, the scoot weights about 45 Lbs and I weight 230 Lbs and it moves me at 28 Mph with 11T motor and 55T rear, using 12.5" tires.
TheFauxFox
Sorry, link doesn't work. Go to the website and search this Motor MotEnergy ME0907 24-48 Volt 300 amp Brushless PMSM/BLDC
TheFauxFox
Anyone else have suggestions?
I'd like to go /w this motor...What should my gearing be? (like x:y)
TheFauxFox
Well, this idea was originally for a science project on electric motor power consumption, but it changed. Don't need a motor anymore. :)
