Motor mount, CKI Laser
cOw
Raleigh, NC
I have a CKI Laser Proto 1 chassis, and I need a new egine mount for it. I am using a Predator 212, the pattern is this-
Mounting base pattern: 162mm L x 75.5mm W - 80.5mm W (6.40" L x 2.95" W - 3.17" W )
Any help would be appreciated.:thumbsup: The previous mount was an inclined one, but it sheared because the previous owner only had 1 bolt holding it.
:useless:I know you all will want pictures, and I will put them up tomorrow after work. Sleep now haha :lolgoku:
:cheers2:
anderkart
Surprise Arizona USA
Cow, you need to start by measuring the distance between your 2 frame rails (where your motor-mount goes), and tell us if they're approximately 3", or 3-5/8" apart from each other.
anderkart
You could buy a flat or 5-degree motor mount instead if you prefer, but most guys with racekarts/engines like yours usually want a 15-degree motor mount to angle the back of the engine up higher, so a racing air cleaner will clear the RR tire.
cOw
Raleigh, NC
Here is a picture. What is the hole in the tube sticking off the right side for?
beansdaddy78
JR. Member
Carbondale IL.
anderkart
Thats a rear Nerf Bar mount:
anderkart
Anderkart, would that mount work with two stroke motors like macs? i didnt know if those other holes might match up or if they could be put in.
Those extra holes in the BMI mount are to adjust the top plate in/out or forward/back.
Some of those holes might line up with a McCullough, but if they did it'd just be a coincidence.
