motor issues
BirdFanatic
Jonesboro Arkansas
Does not mean the guy before me lost the little black cap that goes on it and used what he had at hand (because once the screw moves falls out engine stops working )
Mine had a "factory" cap that allowed movement of the screw(for slight adjustment) afew degrees(hence the walls on both sides of the screw, on the carb... hinders further movement w/ said cap on). The new one I got had a cap 'to' put on... but I left it off. It also came w/ a retaining tension spring. I used no lock-tite on it and it hasnt budged since I set the mixture when I built my engine.
... as far as taking it off... that was a snap(seeing as that noone previously had put any lock-tite on the screw...).
Half-breeder
"Edit" button removed
YOU SIR ARE A:censored:LEDGEND IF WE EVER MEET I.O.U.A BE OR TWO
Before you go praising me... 'that' may not be the 'fix' to your issue(unless it already was a fix...). Another thing to look at is #26 and #1(#1 being the seal to replace). Both are under the throttle idle screw. If you take the screw all the way out youll see a black tab. Pry it up/out(w/ the carb off the engine/fuel line) and ensure the seal is seated properly and that the passages are clean/clear(carb cleaner n compressed air). #26 is also to be inspected and cleaned itself due to the ports it contains (which is the black tab that is/was under the idle limiter).
Carb issues can be alil tricky to troubleshoot/solve... but the design of the GX's system seems pretty simple and greatly functional at a varying degree. The clones w/out the fuel/air mixture screw tend to have to replace the entire carb w/ a Honda part replacement or comparable.
Seeing that the GX200 and clones are widely used in the karting indestry (aftermarket) there is a F/A mixture screw that is evidently used to vary the richness/leaness of an engine at a whim and having #'s on the turning surface allows a measurement to remember for whatever the varying element is (humidity, atmosphereic presure, air temp, etc...). That's probably 'not' an item for any/most of us, seeing that the $ is 2-4X's more than a factory Honda replacement, which is around +/-~15$ if I remember right.
nixta
New zealand
:oops:I think I've solved my flameing exhaust issue guys ..drain the gas cleaned the carb purged the walbro fuel pump and gas tank of the nitro methane and petrol mix that I remember putting in my gokart gas can for my bike racing got it out and put in what we call in kiwi land 91 octane and the bastard runs fine . After all the screwing around lapping valves stripping carbs and timeing indexing spark plugs goddammit I am a Muppet lmfao:lolgoku::censored::censored::censored::censored::censored::censored::censored::censored::censored::ack2::ack2::ack2::ack2::furious2::furious2::furious2:
