emudryj
Hi guys... hope you can help me out here with a lot of questions about this setup...
Remember the Hammerhead with what I though it was GY6 engine??? rocketkart educated me on being a GXH50 HONDA knock off.
It was not starting due to years of sitting in a shed with gas in the tank and carb...
Got the carb that rocketkart suggested en had to replace the plates, but that was not an issue.
http://www.ebay.com/itm/like/161028425454?ul_noapp=true&chn=ps&lpid=82&rmvSB=true
Put everything back together and starts right up on idle...
from there I had a lot of problems...
First.. it would bog down as soon as the gas pedal was pressed..
Any amount of throttle would kill the engine and stop running but it would start right up.
So I started playing with the throttle/idle plastic Phillip screw at the carb, and the other smaller bronze flat screw that I'm not sure what is supposed to do.
It seemed to help a little, at least we could start giving it some gas and it would go, but then, as soon as the kids let go off the throttle the engine would stop running...
Now we would have to give it some choke to get it running, but it would stop more often when releasing the throttle and it would be harder to get it running every time.
I played with the screws a little bit more, but it did not helped.
I was wondering you guys could help...
ALSO, I noticed that there is some kind of release valve in the gear box and some oil had come up from there, it was also really hot when touched so I stopped the kids from using it and came here from directions on how to proceed...
Suggestions? any guess on either one of the issues?
