Mini Monster Truck Go Kart Build
Coalminer
Pineville, WV
I am new to the forum. I am going to start building my kids a mini monster truck go kart like "off the wall" in another thread, which by the way is a great go kart, everyone should check it out if you have not already. Any info that anyone can give would be helpful. The go kart will be a build from the ground up. I would like to find a Carter brothers grave digger body if not does anyone know where I could have one made. So I need every bit of advice as possible from frame to tires and drive train. I mean everything I need help on. Any help would be appreciated.
firemanjim
Just kartin' around....
Houston Texas
WHOA! Slow down..... :lolgoku::welcome2:
You found the right spot! You're fixing to learn more than you thought possible.
For more info on "off the wall" 's build, please read through his build log. It's very informative. I'm sure, once you get to building, he will stop by to throw in a few cents worth of wisdom. His build is great....
As far as that body goes, man, you're just gonna have to start searching high and low.... Look on ebay too.....
Coalminer
Pineville, WV
Thanks for the info. And how do look at his build log. Remember I am new and do you mean the thread or is there a separate log?
firemanjim
Houston Texas
:lolgoku:
My bad..... Yes, that thread you posted in yesterday IS his build log. We start build logs (threads) to keep all the info in one spot. That way, some one like you, can come in and read it. You get to see all that he put into it. The things that were easy, the hard crap..... You get to see it all and how "he" did it. It should give you some idea of what's involved in that type build and let's you know what to expect, if you so choose to tackle a big project...... :thumbsup:
Hi & welcome to the forum.
I thought this thread would be more at home in the intro section; hope you don't mind :)
So, I see you found OFF THE WALL's build, good for you, you're learning fast :thumbsup:
Good luck with the build, we'll be here to help in any way we can
firemanjim
Houston Texas
I was wondering how I got here.......
:lolgoku:
