Is it stock?
Standard Specs
Main jet (VM4/042)
Size 280
Pilot Jet (VM22/210)
50
Needle Jet
Q-2
Jet Needle
5FP17
I had to jet my TM32.
So in my limited jetting experience. I would say that you could "experiment with" the following jets:
200-220 ish main
25 -27.5 ish pilot
Needle jet, likely is TOO BIG, go down in size by one, keep the jet needle.
Now this could be really bad advice, because i dont have the same carb, 2mm makes a big difference in jetting.
So i do have the TM32 flatslide carb, and ran into some issues with jetting that resulted in my spending over $100 in jets and im pretty sure they use all the same series of jets and whatnot....
I would be more than willing to JET YOUR CARB for you!!! It would be on my honda gx390 with a.308 cam on T4 race gas, but it would get you in the ballpark of where you need to be if you are running it on gas with a moderate port job and stock size valves on a honda gx390 engine.
My only requirement is that you pay shipping to and from, and that you buy your own jets as i will ship it back to you in the same condition i got it (stock jets).
I only use genuine mikuni jets as knock offs and drilled dont perform the same.
EDIT
Ehh.,... welll since you live in dallas, if you want to come by my house, we can jet it there man, that is if you are putting this on a big block engine likea gx390/420. Free dyno session while we are at it haha, just shoot me a pm.
Also, i am putting out a public service announcement that I have no idea what air fuel ratio i need to set a small air cooled engine to. Most of the information out there is
12.8-13.1: for automobiles that have radiators etc.
12.5 for old school hot rods that have coolant
11.5-11.8 for air cooled race engines and/or under boost
so... I have gotten A/F reading of 11.1 on gas and it has excellent throttle response, and the plug is a little brown, not even black.... so in my opinion so far, 11.5-11.8 might be a good range to be in? I havent gotten any solid answers here, but it seems like some engine builders purposefully richen up the mixture to keep head temps down and keep it reliable. Just some thoughts. I can jet to whatever, but im not super experienced in what it should be "power wise" vs "longevity"
I could be wrong though.
