Max Torque Centr. clutch sprockets interchangeable?
Jarmo10
Baltimore
Good afternoon!
I just bought a brand new 41 10t Max Torque Centrifugal clutch. I want to move to a 35 chain 10t clutch. Will the clutch drum that currently has the 41 on it accept a 10t 35? I keep getting mixed answers and was wondering if anyone has tried this?
Thanks,
Jason
I doubt that...
I have a maxtorque 12T #35 and I can tell for sure, that the starpattern that locks the sprocket to the drum is the exact (dulled down) sprocket cut with 12 tips (pointless tips LOL) anyway...
12.. I assume that your 10T #41 follows the same rules..
i.e. the starpattern will be a 10tip, just as the sprocket is. (just take a look)
BUT you can easily swap the complete drum (incl the sprocket) the diameters are identical.
A worn out sprocket can be replaced (it's just a snapring holding the drum and sprocket together) but I'd say you can't easily swap for a different size sprocket using the same drum.
Poboy kartman
Senior Moments Member
White Settlement Texas
I doubt that...
OooKay! Let's look at a couple of things here:
First off: 10 tooth #35 clutch bells are rare......
Secondly, it's impossible to fit 10 #35 teeth around a 3/4" shaft....so the gear portion steps down and rides ON THE END OF THE SHAFT.
Soooo....this means a change in chain alignment......
Other than that....how did you enjoy the play Mrs. Lincoln? :lolgoku:
I'm nearly certain I read 12T# 35 before...
but maybe I was hallucinating...
There is however a ten tooth #35 for a 3/4" shaft (elongated with a step down IIRC) but I'm not sure it's a marx torque tbh...
maxtorque has an excellent service ...
so just give them a call and they will give you the ultimately correct answer;
if such sprocket will fit the 10T #40 drum
