Max rpm predator 212
tundrabeagle3
Ca
Im planning on getting a predator 212 , and removing the governor. I have read that valve float on these motors occurs around 5500 rpms . I am just wondering if the rod will be able to handle a constant 5500 rpms with out breaking? I have read similar posts on omb that turn out to be nothing but arguments lol please dont make this a controversial thread. I am looking for a simple answer from some one that owns a clone.
SHACK
The issue with these little motors is the fact that they are splash lube. The rod is plenty strong to maintain 5500 rpm. It’s the fact that the oil in the pan basically turns to a mist in the crank case at high RPM and the rod journal does not receive adequate lubrication. If you maintain the high RPM for an extended length of time the rod journal heats up from the lack of lubrication. This can cause the rod to seize to the crank. When this happens it usually breaks the rod.
If the rod journal has proper clearance and it gets proper lubrication I would not be surprised that it could handle much higher than 5500 RPM.
I have been very impressed with my Predator 212. It has awesome torque for its displacement and with a with a little carb work it has fantastic throttle response. After I got the jetting worked out I installed 18lb valve springs and a super snake free flow exhaust and now it will pull as long as I dare to hold the throttle open. I know that I have had the motor above 6500 RMP in short bursts on several occasions.
tundrabeagle3
Ca
would a heavier weight oil lube it better at higher rpms like maybe 15w40 or 20w 40 ? i wanted to keep it all stock.
r_chez_08
Should be in the shop...
Cornwall, UK
My opinion-
Stock rod and flywheel with stock springs. When you upgrade the springs, upgrade the rod and flywheel.
If you are inside the motor, check the clearance with plastigauge. Should be around .003". Then make sure the rod bolts are torque up nicely.
The two real advantages of the billet rods are the forced oil dipper and Babbitt bearing shells. Arc used to do (and still does for some motors) a billet rod without the inserts. They pile up much more easily. The shells are more forgiving.
