Manco Starbird II? predator 212
Spotisadog
So i just picked up a go kart for my girls, im guessing its a Manco Starbird II (i see starbird ii stickers on it) and it has a predator 212cc engine on it.
Its throwing the chain alot, i see that it doesnt have set screws in the clutch shaft (not sure if thats what its called lol) are those needed, or can i just put some blue loctite on the bolt and that will keep it from walking out?
The 80T sprocket has a bend in it, im going to try to get the bend out of it, but if i cant, what will a 60T replacement do to the acceleration or top speed? Will i need a new chain for it then?
Last question, when the person who put the engine on this frame installed it, theres alot of washer/nut/washer combos used as spacers, are there any spacers i can get that will make it look better, or is that not needed?
Thanks for the help
I can attach pics if needed to help explain my questions.
Staff Murderator
Are you kidding? Photos are always welcome, nay desired. In fact, they should be required when asking a question about something that's not entirely clear or about something we cannot see. :D
And that's about 99.9% of the time...
For real answers to a performance change, we need the diameter of your drive wheels and number of teeth on the clutch, for starters.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Regardless of the numbers.
Going from 80 tooth to 60 tooth will lower your gear ratio.
For example 10 tooth clutch is gonna be 80/10=8 so 8:1 ratio
and the 60 tooth will be 6:1
Changing that alone will increase the available top speed. But As Hellion mentioned depending on tire size (height) will possibly burn the clutch.
So add them photos and some more info. To get actual answers.:welcome2:
Chancer forgot to add. Void where prohibited. You're mileage may vary. Objects in mirror are closer than they appear. See a doctor before taking this or any other medication.
