Manco dingo what engine upgrade ?
Johnwills
Hi everyone I have a manco dingo it has a robin engine think its 5.5 hp can someone please tell me an engine I could fit that is alot more powerful and would fit without to much work looking for about 50 mph and also where to get one please any engine considered
50 on a factory stock Dingo is probably not a good idea. That said, top governed RPM is what it is, regardless of engine choice. While you may end up with an improvement in acceleration, simply swapping to a larger engine with no other modifications won't net you any appreciable top speed gains.
In a nutshell- your 5.5 turns at 3600RPM at full bore. A new Honda GX390 13hp turns at 3600RPM. If all else remains equal, your wheels are still turning at the same speed.
Johnwills
Dingo
Thanks for reply so what is my best option to get a bit more power please?
Thanks
Johnwills
Engine
Thanks is there an engine I can put into my dingo that is quicker without to much changing to do?
Thanks
Johnwills
What's better predator 212 cc or Titan tx200
Hi everyone as in my previous post I am looking for a replacement engine for my manco dingo without having to do much fabricating and have a big more power the two engines I have found are the predator 212 and the Titan tx200 powersport anyone using any of these any any advice please ?
Thanks
dreazoian
Los Angeles
I currently have the predator 212 and im loving it. Never used the Titan tx200 but for the price, the predator is the best! Id say go with the predator you wont be disappointed.
If you could please not create 2 threads for the same topic. I have merged the two together.
I haven't heard of the Titan engine, so I am not too sure how popular it is. Someone might have used it here before
souperman000
Westlake Village, CA
You can put the predator in, but it is common with predator swaps on a dingo that the original gas tank position of the engine hits the back of the seat. You will need to place the tank somewhere else. Preferably above the engine.
CaptCanadia
Acton, CA USA
Your best bet is going to be the Predator because aftermarket parts are going to be much easier to find, many manufacturers like billet have everything you'd want for the 212cc now. Like toystory said, you need higher RPMs to go faster, not power; to do that at the speeds you want safely you would need a stronger flyhweel and con rod.
