Manco American Challenger Fox
gibbywmu
Hi All,
After fixing up 2 carts for my son's friends (A Manco and a Klipper Path Winder), I thought it was time to have our own! I thought $400 for this was a pretty good deal. Its in excellent shape.
I'm just getting into go karts, so forgive some of my ignorance here. I've got a couple questions on this kart.
1) I ordered a new clutch because I think this one needs replacing, and for $23 it seems worth it. Looks like I'll have to mount it backwards to keep the alignment correct. Is this ok?
2) What kind of dual-chain gearing setup is this? The 1st Manco I worked on just had a TC with 2 sprockets total. The Klipper Path Winder had the "wheel peel I think its called, with a Centrifugal Clutch and big sprocket. This one seems to have 4 sprockets total? Not sure what the advantage/disadvantage to this system is? The TC style seems easier to maintain. I'd probably have to get one of those live axle kits for this if I wanted to convert correct?
Couple things I noticed:
- Thought I read another post somewhere, but this vibrates pretty badly between 0-5mph. Once you are over that, its very smooth. Is this because of the worn clutch or is the because of the gearing setup?
- The brake needs adjusting. It has the band brake style, but maybe the shoes are too worn down? The cable seems tight and there is no slack........but when you press the pedal down hard it doesn't stop as well as it should. Do I just need to buy a new band?
gibbywmu
Hi Everyone,
Maybe I didn't provide enough information on my 1st post. So with this dual chain setup, on the 1st set of chain........... I've got a 10 tooth top (centrifgual) to a 23 tooth (on the jackshaft)........the 2nd set of chain is attached to a 9 tooth (on the jackshaft) to a 22 tooth bottom sprocket.
Would this be a ratio of 5.62:1? Maybe not ideal? Thought I've been reading around 7:1 would be good. This has 145/70-6 tires that I believe are 14" diameter.
I really don't like the power of this Subaru engine, so tomorrow I'm getting the Predator 212cc. The only thing I'll have to do is clear out some more room for the bolt holes on the engine plate, so that the engine can slide forward and backward to adjust chain slack. Not sure why they didn't do this initially? On the Manco I worked on before it had that area cleared out. Hopefully my grinder will take enough of it out.....I'll post of picture of the engine plate tomorrow.........
Would like to have this cart go 30-40 mph if possible, but not sure if it is with the current gearing setup? Just learning about that now, and trying to research posts in here relating to it.
Im Curious... How often did you oil that clutch?...
With that big awkward cover on the sprockets/clutch... it makes it impossible to keep regular maintenance easy, like every 2 hrs of ride use for the clutch......
gibbywmu
Mckutzy,
I bought this used this week. Kart looks like in its great shape, but of course hard to say what the previous owner did as far as engine/clutch maintenance. Just purchased a new clutch and I did buy the Predator 212 that I'll be outfitting.............I'll try and sell this older Subaru Robin Engine.
That's another reason I removed that cover. I know it keeps contaminants out, but it makes it impossible to do the maintenance.
Any suggestions on what I should be running for sprockets? Heres a pic of that engine plate. No idea why they wouldn't make it slotted. Stupid. Gotta clear out some more area or I can't slide the engine back and forth for proper chain tension.
gibbywmu
Update:
I removed enough material in the engine plate to make it slotted in the front........but the rear holes I just couldn't get to with my angle grinder (well, I could have but the grinder would start hitting the jackshaft)..... Don't have a torch either :(. Luckily, I just said screw it and the Predator came VERY close to lining up. The only thing I had to do on the Pred was to grind down the rear oil drain screw. The bolt head was too big, and I couldn't scoot the engine back far enough to get the bolts in because the head of the oil drain bolt was hitting the jackshaft. Once I ground that down, it was ok. I was initially worried the chain tension would be too tight, and w/out being able to move the engine back and forth I didn't know if it was going to work..........all ok though thankfully!
Upon further discovery, the bolt that holds the lower brake band ring was bent, and so was the bottom of the brake band ring. Rebent in the vice and tried to get working again. Previous owner must have hit something. Went to hardware store and replaced it with a Grade 8 bolt. Brakes do work better, but I went ahead and ordered a new brake band. This one may just be too stretched out. I think I'll rough up the drum a bit to make sure it gets a good grab.
Anyone have any recommendations on what the best setup is for sprocket size? I don't like the slow take off........I'm sure the gearing was designed like this for a reason. Seems like the karts that have just the "direct drive" system take off faster..............meaning just the centrifugal clutch to 1 sprocket.
