Manco 285 belt question
cerig
Hi,
New to this so please be gentle. Just bought a Manco 285-26. It seems to run good, but not move. I took the cover off the clutch housing and it seems like the clutch is working, but its not grabbing the belt. The belt that was on it it a manco 5959 df. It seems like the belt is too big. When I took the belt off, it came real easy, didn't have to fight it over the pulley at all. That didn't seem right. I guess what I'm wondering is if I have the correct belt, and clutch problems. Or if it's just the wrong belt? Thanks
MittenstheClown
I am not sure about the model number but I have a MANCO cart and it uses the 5959 belt as well. It runs fast and great for the most part and the belt comes of the same way with almost no effort. I was a bit shocked when I took it off but it was running fine before so I assume that is normal. I am a newbie though so if someone knows better then please speak up.
Blazkowiez
Kart Aficionado
Houston, Texas
The belt needs slack to operate properly, if it was tight and required extreme force to remove the belt it would engage immediately and defeat the purpose of a variable drive. I'm pretty sure you do have the correct belt, and for your information the corresponding number in Comet is 203989 and in Rotary it is 8487. Your need to clean your clutches, a picture of the inside of your drive clutch (one on the motor) and a down view of your driven clutch (larger one) will tell me more as well.
