Making your own connecting rod?
CoroTheCat
Builder
Denmark
This may be a stupid question, but I was looking around for connecting rods, and I thought maybe it was possible to make my own. I have a little 3 horse Briggs, that I could try it on. I was thinking about making it out of steel or something like that, since its strong, but I have no clue if its a good idea or not. I am really interested in hearing your thought about it. :)
Russ2251
AZUSA:Powered by LAWN-BOY
Would not be cost effective IMO.
Rods are not steel to begin with. An alloy of aluminum and silicon and are exceedingly light weight.
Also, despite looking simple at first glance, connecting rods are actually a complex part.
As far as I know, 3hp rods are still available and start at about ~$14(US).
fowler
Bullsbrook West Aus
Well con rods are made somehow some where by some one
So u can certainly make one
But do u have the tooling to do it as in mill
And measuring equipment
Don't forget each end of a con rod is a finely machined cylinder
And as for length
A mm out is running under powered to punching valves out
EDIT
Imagine a steel con rod
Bounce bounce bounce
CoroTheCat
Builder
Denmark
Thanks for the replies. I don't have the equipment to build one, I was just wondering if it could work. I am not going to try to make one for now, but if I get the equipment, then I will probably try at some point. Just for the fun of it. :)
Xtreme Yard Karts
Sweet Home Alabama!
I am a machinist, and I have made a lot of rods. I used to make back in day because there weren't many aftermarket ones made, and I have bored blocks and put bigger pistons out of other engines and had to make a custom length rods. The length, pin, and journal dimensions are crucial, and have to be exact. The main body of the rod has to be made with rough (undersized) bores, then split, machined, drilled and tapped. You then bolt the rod together to the correct torque specs, and then finish bore it to correct specs. It is not something that can easily done with basic tools.
CoroTheCat
Builder
Denmark
Sounds really complicated. :) way to complicated for me. It could be something I will try sometime, when I have the proper tools.
