Making a gas tank
athif
does anyone have any tutorial or tips on making a gas tank out of sheet metal? it doesnt have to be functional it just has to look like a gas tank.:D
kibble
I banned myself
If it doesn't have to be functional, then couldn't it just look however you wanted it to? :confused:
I've never made a gas tank but I figure one way would be to roll a piece of sheet metal and weld the seam so you have a cylinder and then weld some round pieces to the open ends. Or you can do something like a box with two pieces that look like square c's or something like: [ and have them form a box and weld the edges together like I drew here using my 1337 h4x0r paint skills:
athif
wood would be kind of hard to bend lol. i Heard u can make a negative out of wood and shape my tank around that, but it looks hard.
athif
Try this, Get some thick conduit put some caps on the end and then use a smaller peice for the inlet. Drill a hole in the top and weld your inlet in.
thanks, i should try that, my school is to garbage to buy a roller or a tube bender.
